I am trying to create a parameter to drive an extrusion with a radius. However, I have had no luck in creating it. I want to use a radius to drive the extrusion length. My example would be the following. I have a 5" radius, I want the extrusion to be 2x the radius; so in this case 10" overall length. If the radius was changed to 2.5". the overall extrusion would adjust to be 5" in length. When I have attempted to create the parameter, it will not allow me to chose the radius. I have named radius in the parameter (if I adjust the dimension, it will adjust the radius accordingly). However, when I hit E (for extrude) and begin to type in =radius*2, it does nothing nor can I hit "ok". Could someone explain to me if the software does not allow for this type parameter or what I might be doing wrong? Thank you for your help, Bear
