Drawings related bug and feature request
O.Tan
Advisor Advisor
O.Tan
For bug:
1. If OpenGL Core Profile is used, Drawings will not work, creating a new drawing from component will result in missing views.
2. If OpenGL Core Profile is used, Ground reflection in Render is green in color
The temporary workaround is to switch to the old slower OpenGL profile to do dimensions and if you want ground reflection to be turn on during rendering.
For feature request:
1. Please allow custom scaling for drawing views, as the default sometime is not enough (and there's no upsize scaling).
2. I'm guessing there's no option to add company logo to drawing title block?
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
O.Tan
August 13 update fixed Bug no.1 but Bug no.2 is still there
Omar Tan
Malaysia
kris_berg
Hi @O.Tan,
Thank you for the update.  I am glad the latest update fixed the drawing issue.  I have asked someone more familiar with graphics to reply to your green rendering issue.  On your feature requests, both of those are on our list for future drawing enhancements.  Each time a customer requests a feature it increases it's priority in our backlog. I don't have a definitive date on when they will be available.  We are trying to get through the list quickly, balancing large projects such as GD&T, quality and performance (by replacing a large component) with smaller projects.
Thank you,
Kris Berg
Fusion 360 Development
Kris Berg
Senior Software Architect - Autodesk
chengyun.yang
Hi @O.Tan,
Regarding the ground reflection green color issue in OpenGL core profile, it is a known issue to us and we will fix it in our Sept release. For now you may work around this issue by using the legacy OpenGL driver. There is no much difference between OpenGL core profile and legacy driver in terms of ray tracing performance since the performance optimization brought by OpenGL core profile driver is mostly for GPU viewport rendering. Sorry for the inconvenience.
Chengyun
Fusion Development Team
