Drawing template
Drawing template
joergen_nilsson
Drawing template
joergen_nilsson
I'm trying to replace the drawing template used on an old drawing (previously created in Fusion).
So I made a new template and saved it as a dwg-file. Then in the the old drawing I click on the old title block and pick NEW TITLE BLOCK where I select the saved dwg-file. I then get the following message:
What to do?
ClintBrown3D
Hi @joergen_nilsson
Why don't you just save the drawing as a template file to re-use it?
The DWG export requires all blocks to be exploded in AutoCAD, see the workflow here.
UPDATE: Here's how to import a title block in Fusion: https://clintbrown.co.uk/2021/07/15/switching-title-blocks/
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
joergen_nilsson
But I do not want to define the drawing views once again. Just change the drawing head.
I followed the steps according to your video link but still get the same error message as shown above.
joergen_nilsson
I got it now from the second of your videos :-).
Many thanks
