- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Fusion forum,
I would like to draw this object (see reference photo) in Fusion. The object has a slot in the middle. I was able to sketchthe bottom and middle layer as two seperate components, but I'm not sure how to add the top layer to the object since it sticks out over the middle one. How do I go about designing this so it will be one body?
I added the dimensions of all layers as attachment. The extrusion of all layers are: L1 (bottom) 17mm, L2 (middle) 21mm and L3 (top) 22mm. The object is horizontally symmetrical, the middle layer is 2mm from the edges of the bottom layer.
Any help is greatly appreciated!
