Hello all,
I'm experiencing a strange problem, that might (?) related to the recent update of Fusion 360 : when creating a drawing based on a design, I find that I can't create an isometric Base view of my design anymore.
When I click the Base view icon, I get the usual Drawing view dialog box and can select the various options normally. However, if I choose any of the isometric orientation, the temporary view that is hovering over the drawing sheet is replaced with a small square, and if I click OK, I get an empty red rectangle rather than the expected rendering of the design. Normalized orientations work OK.
When documenting a design that includes a few parts, I like to place a general view of the complete assembly in a corner of each part's detailed drawing. I add a leader comment to show where the part goes into the assembled system. I've found that an isometric view works quite well for this purpose, unfortunately, this seems to be broken for now. Any suggestion ?
Your help is appreciated,
EDIT : I just tried again before posting this message : things have changed, I now get a truncated view of the design, always in the same isometric orientation irrespective of the isometric orientation selected in the dialog... ???
