Drawing is a jumbled up mess of components.
JFKANSAS
JFKANSAS
I tried a distributed design and instead have a very disrupted design. Everything looks fine in A360 view, but the drawing has multiple copies of parts in several angles that just aren't there.
JFKANSAS
I sent links to files and a drawing PDF to the case number on this.
It is the first time I used the distributed design feature so not sure if everything is setup right. Not sure if the distributed method is ready for prime time yet...
RajkumarIlanchelian
HI,
Thanks for submitting the details to our system. If you don’t mind can you send the details directly to raj.kumar.ilanchelian@autodesk.com as well ?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
JFKANSAS
Sent, let me know what you find after lunch at White Castle. 🙂
cmiller66
Hi JFKANSAS,
Checking in on this one, have you had a chance to try this again since the last update was posted?  This issue with drawings and distributed design should be fixed now.
Chris
