drawing from design
drawing from design
hgp-precision
drawing from design
hgp-precision
Community Visitor
Community Visitor
Can anyone help me with this ?
When I send my Design to Drawing it has just started giving me a blank screen with just a cross to move around and cant click onto anything else so have to shut it all down,
Have tried an uninstall and re install but still same.
Video attached to show.
jhackney1972
Recording a video using a camera on the screen is not a good way to show your problem.  This is probably a graphic card/driver issue.  Make sure you have up to date graphic card drivers and your are using your dedicated graphic card, if you have one.  This can be determined by running the Graphic Diagnostics from Fusion.  Also you could try changing your Graphic Driver in Preferences.  You can also see if your DirectX configuration is correct by going to a Command Prompt and running the command DXDIAG.  I am assuming you are using a Windows based computer, for a MAC, I do not now the method for checking your DirectX configuration.
John Hackney, Retired
HughesTooling
@hgp-precision As well as what @jhackney1972 suggests, make sure Windows is also fully updated.
Mark
Mark Hughes
Owner, Hughes Tooling
g-andresen
please install a (free) screencast app and record  a screencast, beginning in design mode.
günther
sorry, I have overlooked a few posts
