Drawing from animation mispositions some components, others are correct.
leonor_dias_20
leonor_dias_20
I have completed my design which has several components. I am amble to create a drawing from design where all the components appear. I go on the animation tab to make an exploded view and it works. The problem comes when I try to do a drawing from animation. 17 components appear like in the exploded view of animation but 6 stay in their original place. None of the components is grounded. I have attached screenshots of what it is meant to look like (animation) and what it is producing (drawing)
When I create the drawing from the animation I get this message as well:
Warning: Changes have been made to a referenced design. You can update the drawing from the button in the Application Bar.
When I try to update, I get:
Error: The referenced file being opened is the same as the one currently open.
I have attached the file of my assembly.
Any help is appreciated.
Best
TheCADWhisperer
@leonor_dias_20
If you go back to the Design workspace and run the command Ctrl b (on Windows) or CMD b (on Mac) do you seen any unresolved issues highlighted in your Timeline?
leonor_dias_20
Thank you for you reply. I have fixed all the error messages but the drawing is still not matching the exploded view shown in the animation tab. Not sure what can be the problem. I have attached the new version without bugs.
