Drawing Drawer Fronts
will.dameron
will.dameron
Brand new user to 360 here, but I am hoping to use it quite a bit in the future, and have been immersing myself in it the last day or two. Currently, I'm trying to design a bedframe with drawers under it. I would like to be able to cut out the drawer openings with an 1/8" end mill, and then use the piece which is cut out as the actual drawer front. I tried creating two rectangles, offset by 1/8", but I can't get the inner rectangle to disappear/extrude away/what have you. I think I could probably just make a toolpath which worked correctly, but I'd rather be able to see the whole thing in my drawing - any suggestions? What am I doing wrong?
A few more details: I have a body that is 23/32 thick, have sketched an outter rectangle on it, and an inner rectangle, and I want the space in between to disappear, and after I'm done drafting, want to create a toolpath that will get rid of the area betweeen the two rectangles, and then save the piece which is cut out to use as a drawer front. Make sense?
Will
Phil.E
Welcome to the Fusion 360 Forum.
The outer and inner rectangle need to be in the same sketch. Are they? If so, you should get a result like this when you extrude the offset gap.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
will.dameron
Thanks for the quick reply:)
I sort of got it to work... I had both rectangles in the same drawing, but I wasn't changing the 'extrude' into a 'cut' mode, and I was trying to use the 'extrude to' feature, to the back of the panel I wanted it to cut through, which apparently doesn't work. When I just pushed/pulled manually, purposely going to far, it snapped back to the inner plane of the body, and it worked.
Now I'm having a heckuva time mirroring that geometry to the other side of the drawing. There's no way to 'mirror' the cut away space between the rectangles is there? I have already mirrored the body, earlier, without the drawers cut out. Now, if I delete the body to try to mirror the updated version, it causes quite a few issues, including deleting the very body I want to mirror over. Grr... Any thoughts?
Will
Phil.E
There is an option to mirror "feature" in the mirror dialog.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
