Drawing dimensions
Drawing dimensions
matej.biro
Drawing dimensions
matej.biro
Hello, is it possible to change dimensioning style as it was before (see pictures) and have always "Display leading zero" active without clicking on it every single drawing that i make? I coudnt find it in preferences.
Thank you.
HughesTooling
Here in preferences.
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Note, this will only affect new drawings.
Mark
Mark Hughes
g-andresen
you can change settings for existing drawings via Browser > Document Settings  ..
Embed Image fails > attachment
günther
jhackney1972
@HughesTooling is spot on about how to configure your preferences about leading zeros in your drawing.  I just wanted to point out that you may not realize that these settings ONLY appear if you have selected either ASME or ISO as your Standard.  If it is set to "Inherit From Design" you will not see them.
John Hackney, Retired
matej.biro
Thanks, after i changed Standard to ISO Display leading zero appeared.
And what about those dimensions where numbers are not writen directly on line but in aditional line that is linked to dimension line? Now i have to every second/third line manualy edit and its rly time consuming. I dont see any advantage in that new feature and most of time it overlaps with next dimension lines.
