Drawing dimensions, radius problem.
hato54
hato54
Can't dimension the radius of the bended antenna or set centermarks.
WHY?
The 3D and the drawing file is attached.
ryan.bales
Autodesk Support
Autodesk Support
You really won't be able to dimension that because the bend makes the arc not planer to your view.
The best solution would be to cut a section through the middle and dimension the arc on the section:
Ryan Bales
Fusion 360 Product Support
hato54
Thank You @ryan.bales
/Håkan
