Drawing dimensions changing their own references
martin3HJUA
martin3HJUA
I've seen this a few times now, but have finally caught it in the act and have an example from the drawing's history because, embarrassingly, this one excaped into the wild. Notice how these dims have altered on their own. This is a pretty egregious bug! moving dims.jpg
-KyleWilliams-
Hey Martin,
Would you be able to provide a little more detail on when this is happening. Has anything changed in the model? Is this after clicking to update the drawing? I see your previous post you were unable to share your data set, if its possible to share in this case please do to fusion.360.drawings@autodesk.com
The big thing I notice is that previously associated center lines are missing in the second image.
Kyle Williams
Senior Customer Advocacy Manager - Design and Documentation
Ontario, Canada
Become an Autodesk Fusion Insider
martin3HJUA
The model hasn't changed significantly - indeed the location of those holes have stayed the same since day dot. I suggest therfore that it is the centre lines that have probably what has moved - so thanks for spotting that.
I can only say that between two saves, the lines moved. I went back through my history to find one that was correct.
I have now changed my use of threads so they don't appear modelled in the drawings.
I can share this model. Would you like an export either side of the error?
-KyleWilliams-
Lets start with the files you've suggested. If we need further details I will reach out.
Thank you for bringing this to our attention.
Kyle Williams
Ontario, Canada
