Drawing cut view issue
dmitrijs.kulikovs
Observer Observer
dmitrijs.kulikovs
Observer
Observer
When longitudinal cut is made view of part is shaded.
liang_chen
It could be dataset specific issue. Please share the dataset, or you can share the link of dataset by email. Thanks
liang.chen@autodesk.com
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
dmitrijs.kulikovs
Observer
Observer
Yesterday everything was OK.
Not sure what do you mean "share the dataset, or you can share the link of dataset by email"
May I ask you to give some instructions.
liang_chen
Please share the link of file with us, and allow downloading. Thanks
Fred Chen
SQA Engineer
Autodesk, Inc.
dmitrijs.kulikovs
Observer
Observer
I have send you link.
But this problem with absolutely newly opened drawing.
liang_chen
Thanks for sharing the dataset. Checking the details of the 3D design, body 10 and 11 are bad body in UKP210-J7. Showing as the snapshot, the solid body is open and the face is too thin. It is not a quailfied solid body. Please rebuild these bodies in 3D design.  Is this body created in Fusion, or imported from other file format ?
In drawing, you can hide the bad bodies to get the correct section view, showing as the second snapshot. Hope it works for you.
Fred Chen
SQA Engineer
Autodesk, Inc.
dmitrijs.kulikovs
Observer
Observer
Fanstastic. Thanks a lot.
Never come across such problem.
This bearing housing I don't remember where was download, but 99% downloads are made through "Insert manufacturer part"
