drawing components
drawing components
Message 1 of 11
drawing components
Hi there,
             I have flat spokes radiating from a central boss which have been modelling using radial pattern, when the drawing is generated using just one spoke to detail the parts list only calls up one required instead of the total, is there a way to solve this call off without having to add a note to this effect.
cleevista      (Geoff wheeler)
Replies (10)
Message 2 of 11
TMC.Engineering
Can you post you model and maybe picture or screencast to illustrate your issue?
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
Message 3 of 11
Hi There, Thanks for your very prompt reply and as requested I am attaching the Fusion file where the spokes are shown supporting the top plate, I hope this will help,kind regards,cleevista (Geoff Wheeler)
Message 4 of 11
TMC.Engineering
huh, I don't see an attachment
Timm
Engineer, Maker
Message 5 of 11
TrippyLighting
Are you patterning components, or bodies ?
Components are counted in the BOM, bodies are not.
Message 6 of 11
Hi there, In reply I confirm that they are all components, also in the drawing of the main assembly the parts list shows 12 spokes however when I produce a drawing for a single spoke the parts list or BOM only shows one, it mean the fabricator has to refer back to this main assembly, therefore I assume this is the way the programme is meant to work,kind regards,cleevista (Geoff Wheeler)
Message 7 of 11
Message 8 of 11
Hi there, Sorry you have no attachment so lets try again,kind regards,cleevista
Message 9 of 11
TMC.Engineering
nothing,  Are you maybe replying from your email?
if so, try instead attaching on the forum through a web browser, not through email.
Timm
Engineer, Maker
Message 10 of 11
cmiller66
Hi cleevista,
I have a suggestion for a workaround, with the caveat up front that it is not not very elegant.  That said it should accomplish what you are trying to do.
1.  Open the design (has 12 spoke components)
2.  Open the detail drawing of the single spoke
3.  Return to the design > From browser, Ctrl+ or Shift+ select all the spokes > Right-click > New drawing
4.  In the Create Drawing dialog, expand Destination Drawing and select the Spoke detail drawing > OK > Place the view in the drawing
5.  Parts List > At the prompt select the view you just placed > Place the BOM - the Qty will be 12
6.  Delete the last view > Save the drawing
Now this drawing has the single spoke detail with the full assembly spoke count.  For the time being does that work for you?  Please note we *are* actively working on better control around issues like this, including adding/removing components from views, as well as edit of tables so this type of extra step should not be required down the line once these new features are ready and available.
Chris
Message 11 of 11
Hi Chris, Many thanks for your reply and your workaround is fine, I have now produced the detailed drawings required using this procedure, kind regards,Cleevista (Geoff Wheeler)
