Drawing a delta wing for streamliner
bcoughlin1954
bcoughlin1954
 I am attempting to draw a delta wing.
I inserted a picture of a wing chord and traced it with splines.
I think that I should now copy the sketch to an offset plane.
scale the second sketch.
Loft the two.
I cannot copy and paste to the offset plane even though I have watched a webcast about copying and pasting to an offset plane several times.
Am I doing some fundamental error in drawing with Fusion?
Bryan
The process is somewhat vague, but here is how you can copy a sketch.
1- create your sketch that you want to copy
2- create your offset plane
3- create a new sketch on this offset plane
4- exit this sketch
5- open the first sketch, select all and ctr-c to copy then exit
6- open the offset sketch and ctr-v to paste.
Now, sometimes, and I think depending on from where the offset plane has been created, your copied sketch might not lign up. So you'll have to move it manually.
Hope this helps
bcoughlin1954
I just can't get it right.
Everything seems to work ok till step 6
There is just some simple thing I am missing
HughesTooling
I've just discovered you can copy curves from one sketch to another while editing the second sketch. Just create an offset plane, start a new sketch, select curves from the first sketch and copy then right click and paste.
Mark
Mark Hughes
Owner, Hughes Tooling
@bcoughlin1954
I've recorded a screencast quickly showing how to copy a sketch and loft an airfoil in Model and Patch environments.
Model env gives you a solid, Patch gives you a surface. Which one to choose depends on what you want to do with the wing downstream.
  1. Make sure your airfoil is closed (to form a profile) otherwise you will not be able to loft.
  2. If your wing planform is straight, you can extrude it in Patch without it having to form a profile.
Hope this helps.
bcoughlin1954
Thanks I will check it out asap
Bryan
