Draw line between points
masar314
masar314
Hello guys, I can't find a way to do this simple task.
I've created a plan through 3 points, created a sketch on that plan. Now I would like to draw lines between those 3 points (which are obviously inside the same plan), but the lines doesn't snap to the points no matter how much I zoom in.
Is there a feature that draws a line between 2 points selected from the "Construction" folder?
Spent a whole hour trying to figure it out, and it starts to drive me crazy. By advance thank you
davebYYPCU
Sketch > Create > Project > Project, select the 3 or more points you need.
If you select Linking, they will be purple, not linked, will be white points.
Then your lines will snap to them.
Might help….
masar314
That was exactly what I needed. Thank you so much for your quick help.
