Dragging a named view to the render gallery doesn't work
robduarte
Message 1 of 8
robduarte
I'm dragging a named view onto the Render Gallery and nothing happens. Am I missing something? See the screencast at https://youtu.be/YS0eCzLUw_c
Rob Duarte
Associate Professor in Art, Florida State University
Co-Director FSU Facility for Arts Research
http://art.fsu.edu/rob-duarte/
Twitter | YouTube
Replies (7)
Message 2 of 8
Phil.E
What happens when you click Save on the design?
I'm finding that all named views are rendered after the design is saved with the new view in it, regardless of drag and drop. Does that happen for you?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 8
robduarte
Yes, if I add a Named View and explicitlty save the design then it automatically shows up in the render gallery when I go to the Render workspace. Does this mean that the instructions that appear in the render gallery are wrong?
Rob Duarte
Twitter | YouTube
Message 4 of 8
anavaidya
Hi @robduarte,
You can't directly drag a Named View into the "Render on Save" area. Once you save a file, the new view is saved in the render gallery. You can then drag that view to the "Render on Save" area. The next time that you make changes and save the file, the view gets automatically rendered. Here is a video that illustrates this functionality.
If you have further questions, let me know.
Aradhana Vaidya
Customer Success Engineer, Rendering & Visualization
Message 5 of 8
robduarte
It makes total sense when it's demonstrated.
I have to say that it's not clear that the left portion of the render gallery is a discrete pane with its own purpose - until after you move something into it.
The text "Drag and drop views here..." is confusing because the only thing that's explicitly labeled a "view" in Fusion 360 are Named Views. I'm not sure how a user would know that the thumbnails in the render gallery are what are being referred to as "views". Maybe it should say "Drag and drop thumbnails..." ?
Rob Duarte
Twitter | YouTube
Message 6 of 8
anavaidya
You are right, it's confusing. The term "view" is misleading. We discussed this internally and are considering changing it to "drag and drop thumbnails...."
Aradhana Vaidya
Message 7 of 8
robduarte
Yes, I think that would make a lot more sense.
Rob Duarte
Twitter | YouTube
Message 8 of 8
GLecakes
Has there been any progress in 're-naming' the instructions or what you call a 'view' when rendering? The way I see it, the 'views' in rendering store a lot more information than just the view and should be called a 'rendering'.
When I first the render gallery and the small window that says Render on Save stating:
"Drag and drop views here to enable rendering on save for future versions" I had no idea that this was separate from the 'named views' in the browser bar. So I created named views and then tried to drag and drop them to that location.
Had I not found this post I would still not understand from the interface and the instructions provided.
