drag-n-drop and copy-paste between designs
I've noticed twice now,
I open browser to drag n drop into scene to begin sketch and the error pops up saying " Please save before adding new component"
If i double click on that same item to load up it opens without an issue and i am ready to continue work on that item.
This seems to be random unless i am unknowingly doing something different.
TrippyLighting
No that is not random!
Inserting an exiting design into a new one requires you to save the new design first.
Opening an existing one does not require you to save it first as that would obviously not make any sense 😉
Apologies if im not explaining properly.
If i dbl clik on an item from my browser Fusion says open into new empty
field.
If i drag n drop that same item from my browser into the same new empty
field.
Fusion thinks i want to add to the new yet empty scene, although there is
no existing file to save.
field.
field.
TrippyLighting
It would be great if you could make a screencast to show that behavior.
will work on learning screencast.
