Draft - Fail
Draft - Fail
natemclain
Draft - Fail
natemclain
I'm trying to do a simple draft on a vertical surface and it has worked on the other areas I tried but it won't work on this one. The error message is less than helpful unless I just don't understand it.
See the attached screen shot.
Any input would be appreciated!
Nate
lichtzeichenanlage
Can you File -> Export and share the modle?
g-andresen
Hi Nate,
I think, the reason is the fillet at the bottom, which will be intersected.
günther
