Double Loop Grease Groove Inside Bore
morgantooldie
morgantooldie
I am trying to make a bushing with a double loop grease groove in the bore. The bushing measures 2.875" OD with a 2.5" ID and 1.75" long. I want the grease groove to have a .1875 radius and to be cut .0625" Deep.
Can someone explain to me how to model this, send a f3d file, or send a screencast? Thanks
g-andresen
Please share the file with basic geometry.
File > export > save as f3d locally  > attach it to the next post.
günther
morgantooldie
I have the bushing modeled but I have no idea where to even start on the groove. Ive attached an image I found on google of what I am trying to accomplish
TheCADWhisperer
Do you need it geometrically correct (as in the machining process), or do you just need cosmetically "close enough"?
Do you want double cross or single cross "figure 8"?
morgantooldie
Close enough... within .010" or so. Its just a lubrication groove
TheCADWhisperer
See previous reply.
Check the depth/radius/angle - I didn't pay attention to your dimensions, just quickly through it together as an example.
morgantooldie
I was able to go through the design history of your model and figure out how you did it. Thanks a lot
