Double-Ended Ball Joint/Socket Issue
StellarFusion
Message 1 of 48
StellarFusion
I have a tube with a double-end ball joint that I'm attempting to connect to sockets at each end.  However, once I get one connected them attempt to connect the other joint to the other socket, it doesn't stay attached to the first socket.
How can I get the joint to connect at each end?  Please see video.
Replies (47)
Message 41 of 48
TrippyLighting
@StellarFusion The "squirrely behavior" in your design and the reason you are receiving error messages about joint conflicts is that after your Ball37 joint your design is simply over constrained.
When trying to apply just one additional ball joint between the correct upper part and one of the free truss ends The joint solver simply cannot connect the two joint origins, because they don't precisely align. Precisely in this case far exceeds what you can measure with a caliper. You'd have to have a rester electron microscope to measure that. Or better. The precision needed is the internal precision of Fusion 360.
The root cause for that lack of precision are the fully undefined and imprecise sketches in the design.
That is also the one and the only reason why this works in the last two designs I posted. If you start with constrained and dimensions sketches it will work, otherwise it will not. There is really no other magic at work here.
Another thing that no one has mentioned here is that this design is a fully constrained, rigid design. As it pertains to Fusion 360 the ball joints are completely unnecessary to create this design. It can in fact be created with a single rigid group joint.
Message 42 of 48
TrippyLighting
@jeff_strater I also have seen "squirrely behavior" particularly when using ball joints.
The reason for some of that behavior can probably be explained by ball joints not being implemented using quaternions as one of the developers has explained in depth in this thread. She also provided excellent reasons why that choice was made.
As everything in life one has to make compromises along the way and if its known that there are somewhat mathematical reasons for this then maybe precautions can be taken to help the joint system a little along when creating such an assembly. So I did use a little trick .
First I used a slider joint between the upper and the lower frame, with some sensible joint limits. Setting sensible joint limits is always a good idea. That however did not work and I also got a joint conflict. So I opened up one more degree of freedoms and changed the slider joint into a cylindrical joint. Voilá. Problem solved 😉
However as I've said before and as you have confirmed, there is absolutely no way to get this to work when one does not work precise. That is not just true for Fusion 360 but for any other CAD system. One would run into these same problems using Solid Works or any other CAD system.
Message 43 of 48
TrippyLighting
@chrisplyler wrote:
@TrippyLighting
Dude, I'm getting awfully tired of seeing you help people with examples that aren't rendered and self-illuminating. What gives? Man Very Happy
Uhh, yeah, sorry for slacking off.
Would this work? It did not quite turn out the way I had hoped. I've yet to produce a single rendering with good caustics in Fusion 360
Message 44 of 48
TrippyLighting
@chrisplyler Forget the other ender. How about this one ?
Message 45 of 48
chrisplyler
Way better! Now I'm happy.
Would love to be taught how to lay that carbon fiber base down.
Message 46 of 48
TrippyLighting
That is actually embarrassingly simple. I got lucky 😉
I created a large flat block and applied the carbon fiber twill texture. Thats it!
The nice anisotropic "streaky" effect comes from the small light sources on the underside of the upper hex frame.
Message 47 of 48
chrisplyler
Ooooooooohhhhhhh... I thought it was some Environment I was missing. Thanks!
Message 48 of 48
TrippyLighting
Nope. I use the "cool light" environment in Fusion 360 and turned it down to 1000 lux so the incredibly weak emitters in Fusion 360 can take effect.
