Seems I don't understand something very basic 😞
Created two components - screwdriver handle and tip. Then created the screwdriver itself as another component, using a rigid joint between the handle and the tip.
Unfortunately when I try to use that third component for the solid sweep, it doesn't allow to select the whole thing - either the handle or the tip can be selected, so the sweep is done only with the part of the screwdriver.
I tried to combine the handle and the tip into one body, but Fusion doesn't allow to select any part as the target body, only as the tool body.
Created a rigid group with the handle and the tip - didn't change the behavior during the sweep, still can select only one part of the whole thing...
Another issue - can't select any faces on the screwdriver while trying to offset faces...
Would really appreciate if someone can tell me what I'm doing wrong here...
Thanks !
P.S. Had to zip the Fusion archive because the forum didn't allow to attach .f3z file ???
