Dog Harness
Dog Harness
figueroa_116118
Dog Harness
figueroa_116118
Community Visitor
Community Visitor
Can someone help with the drawing
TheCADWhisperer
@figueroa_116118
Is this your very first Fusion 360 project?
sutherland-
Hi @figueroa_116118
To create a drawing please follow these steps:
1. Open the design.
2. Click Model and select Drawing from Design.
3. Select options in the Create Drawing dialog box.
  • The drawing file can be created from a full assembly or individual components / bodies.
4. Select the appropriate drawing, template, standard, units, and sheet size options.
5.Use tools in the drawing workspace to place views and annotation in the drawing workspace.
Note: A drawing can not be created with only sketch elements or surface bodies. The drawing will not auto-populate.
6. To Print or export the drawing, choose one of these methods:
  • Select File > Print and choose the preferred output format.
  • Select the OUTPUT dropdown on the Tool Bar Ribbon and select the preferred output format.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Warmingup1953
Certainly. Can you explain and perhaps illustrate what you need to do and how far you have gotten with your design in Fusion 360.
