Documents cannot be deleted, no reference or drawings exists
ernie9TF2T
ernie9TF2T
Documents even without references or drawings cannot be deleted. Message is the standard that it has relations and cannot be deleted.
These are stp uploads that also cannot be moved as no folders are shown.
Creating a drawing does show up on the data panel.
gautham_kattethota
Hi @ernie9TF2T
It could be because the document/documents you want to delete were referenced by other documents at some point in time, but not anymore.   In other words, previous versions of the document might have been linked/referenced by some other document and that link could have been severed in a future version.  Is this the case with your files?  Fusion prevents deleting the  document that was previously referenced and shows the message you are seeing.
We are aware that this is not a good experience and want to fix this.
Regards
Gautham
Gautham Kattethota
Software Development
TrippyLighting
This is an ages old issue and your more advanced users have been aware of this for several years (4-5).
When do you intend on fixing this ?
