document tabs disappear
sricci.design
sricci.design
I after I created a drawing from my model I clicked back on my model tab only to find that the drawing tab went away. I tried to re-open the drawing file through my window drwop down menue but it only shows that the drawing file is still open. I cannot access the drawing file with out first closing the 3D model file. I also cannot click on the drawing tab to get back to the drawing file since it disapperaed. Any way I can fix this?
-S
kris_berg
Hi @sricci.design,
Unfortunately we have not seen an issue like this before.   I would suggest you close Fusion 360 and then relaunch.  If you are able to reproduce the issue, can you send me (kris.berg@autodesk.com) the steps to reproduce?  Also please include information on your OS (Windows or Mac and version).
Thank you,
Kris Berg
Fusion 360 Development
Kris Berg
Senior Software Architect - Autodesk
sricci.design
Hello Kris,
Yes I tried relaunching F360 and even fully shutting down and restarting my computer. I am running F360 on Mountain Lion. Here are the steps that occur when I encounter this problem:
1) open fusion 3d file from c-panel
2) create drawing from component in file
3) click back on 3d file tab
.... Now the drawing tab goes away and I cannot access it. Also I just tried opening two different 3d files from the control panel and no tab showed up. I cannot click back and forth between two different open files. I hope this helps and that you can resolve the issue.
-S
Sent from my iPhone
Sent from my iPhone
On Jun 9, 2015, at 5:34 PM, Autodesk Community <community-no-reply@autodesk.com> wrote:
Hi sricci.design,
kris.berg (Employee) mentioned you in a post! Join the conversation below:
Re: document tabs disappear
Hi @sricci.design,
Thank you,
Kris Berg
Reply | Accept as Solution | Give Kudos
Autodesk Community sent this message to sricci.design@gmail.com.
You are receiving this email because you were @mentioned and the message matches your subscription to a topic.
To control which emails we send you please go to, manage your subscription & notification settings or unsubscribe.
kris_berg
Hi @sricci.design ,
Thank you for the reply.  We are still trying to reproduce the issue.  I will let you know as soon as we have more details.
Thank you,
Kris Berg
Kris Berg
sricci.design
I reset the tool bar and that fixed the tab disappearing problem.
kris_berg
Hi @sricci.design,
Glad to hear you found a solution.  I am sorry we could not be more help.  Unfortunately we could not reproduce the issue.
Thank you,
Kris Berg
Kris Berg
