Do formulas support If-Then?
SGoldthwaite
SGoldthwaite
I'd like to do a sketch pattern where the number of copies varies with a dimension.  For example, let's say I have a circle and the diameter variable is d5.  In the quantity field of the pattern dialog, I'd like to have something like this:
If d5 <= 0.5 then 7 else 4
if the circle diameter (d5) is less then or equal 0.5, then pattern quantity is 7, otherwise it's 4
jeff_strater
no, control-flow logic is not part of Fusion equations today
Jeff Strater
Engineering Director
SGoldthwaite
I thought that was the case, thanks for confirming
j.preston.6
Are there any plans to include control-flow logic in the future?
vladimir_michl
It can be done with an "arithmetic workaround" in most cases - see:
CAD Forum - How to use conditional parameter values in Fusion 360? (cadforum.cz)
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
