Display/Scaling Issues with Fusion and Windows 10
I'm attempting to run Fusion 360 on a screen with 3000x2000 resolution. It loads alright, however all of the menus and the initial start screen load tiny. I tried lowering the resolution and turning off Display Scaling to no avail. Does anybody have suggestions?
Justin
innovatenate
Autodesk Support
Autodesk Support
There's a suggestion in the below link you may find useful from @jason.tebbe
https://forums.autodesk.com/t5/ideastation-request-a-feature-or/adjustable-width-length-for-window-p...
I hope this helps.
Nathan Chandler
Principal Specialist
Thanks. I am using a Surface Book, and I cannot seem to to turn off hardware acceleration with the GPU. Has anybody run into this problem as well?
