Display resolution problems windows 10
So I've been playinig with Fusion 360 for a few days on and off now and I have an issue with the text sizing and related location of certain items in the workspace.
Computer is a Dell M4800 with a Nvidia K2100M GPU (2GB). Running Windows 10.
The problem is that I have a 3200 x 1800 resolution built in display and a 1920 x1080 24" external display. Due to high resolution main display I have DPI scaling set at 175% so I can read text in normal apps. My external monitor is set at 100% scaling for DPI. But when I open Fusion 360 on my external monitor it is scaled huge as if the settings from the main monitor were carried over to my external monitor. This only happens with this program. I do not have this issue normally.
Also for reference, when I open up the help files from fusion on my external monitor again the text is huge. This is why I think it is related to Autodesk and not my computer.
I've tried it both with High DPI scaling enabled and disabled (right click, properties, compatibility) without any noticeable difference.
Thoughts?
And sorry if this isn't the correct forum. Doesn't appear to be one for issues like this.
innovatenate
Autodesk Support
Autodesk Support
Hi Welcome to the Fusion 360 community! There are some known limitation around high resolution displays at the moment. We are working towards improving the current behavior.
I note some user's have posted temporary work-around solutions in the below ideastation post.
http://forums.autodesk.com/t5/ideastation-request-a-feature-or/adjustable-width-length-for-window-pa...
I hope that helps. Please let me know if you have any questions.
Nathan Chandler
Principal Specialist
