Display lines on the body when moving
tell me what settings to change, so that when a stirred, and the rotation model has not disappeared visible lines on it?This happens every time when I rotate the model, as if someone at the time disables the display lines in the camera settings
jeff_strater
I think I understand your question, but I could be wrong, so please correct me if this is the case.  When you rotate, zoom or pan the view in Fusion, when your model is very large, it disables the "edge display" on the body.  This is done to improve performance.  There is no option to disable this.  When the view operation is over, the edges should re-appear.  If you are seeing some problem with this (for example the edge display does not come back on), can you please post a screencast or video showing the behavior?  Then we can see whether there is a problem with Fusion.
Thanks for posting.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
All right, edge off from the object while rotating. all videos from channel fusion, by the rotation of the body, the eges are always visible, I have some problem, it is difficult for the eyes when you work fast.
In addition, when using the manipulator 3d connexion, edges do not appear immediately, but after a few seconds. it is very hard to watch. I would like to turn on edges forever
chengyun.yang
If you want to always display the edges when doing the rotating, you can go to Fusion Preference->Graphics tab and change the "minimum framerate" to something very small(e.g., 1). The default value is 35, which means if the frame rate is below that value, we will suppress some visual effects or edges to maintain the framerate.
Chengyun
Fusion Development Team
