display driver has stopped responding
Cruickshank01
Cruickshank01
After the July 26 update to F360 today, when I start it up I get the error msg:
"Display driver has stopped responding and has recovered.
Display driver Windows Kernel Mode Drive, Ver 341.44 stopped responding and has successfully recovered."
In Model mode, bodies are showing in solid black instead of normal Glossy Aluminum - Anodized Glossy (Grey)  but the data panel is showing them correctly as Grey.  In Cam mode they are still in solid black until Simlate is activated, then they are green, unless if Transparent is checked, they are black again.  All has been good until today's update.
Screenshot & Diagnostic Logs attached
Any thoughts?
Dell I580 with fully loaded ram, Win7 Sp1
27" ViewSonic Monitor
[GPU Information]
GPU Device: NVIDIA GeForce 210
GPU RAM: 512 MB
GPU Driver API: DirectX 9.0
GPU Driver Verison: 341.44
GPU Driver Date: 02/04/2015
[Graphics Effects Settings]
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Notes]
1. If you see any graphics display abnormalities, updating to the latest graphics card drivers could help resolve them; please check with your GPU vendors to download and install the latest graphics card drivers.
2. The effects could slow down the graphics rendering; try to limit them for optimum performance.
[Limit all effects to provide optimum performance]
chengyun.yang
I noticed that you are using DirectX 9 driver. Can you please try to switch to use DirectX 11 driver to see if it makes any difference? You can do that in Fusion Preference Dialog->Graphics driver. You need to restart Fusion to get it to take effect.
Chengyun
Cruickshank01
Thank you, Chengyun,
Easy and quick and a complete solution.  Thank you for your quick response and for your excellent support.
Mike
