DIN Titleblock Template?
Hey,
I need a german DIN titleblock. I´ve been  trying for hours now, I´ve played around with QCAD and downloaded dozens of dwg templates but none can be imported, if they can they lack the attributes and I can´t enter information.
I don´t want to use AutoCAD, I have no use for it and this shouldnt be a problem to begin with. Can´t you just provide  a bunch of working templates (the common ones)?
Does anybody have a template I can use, it looks like this?
900px-Schriftfeld_DIN_6771-1.svg
cmiller66
Hi Marc,
Thanks for the post.  We are currently working on an in-product block editor, so you'll be able to create and edit titleblocks within Fusion.  This is still in progress though and will be a number of releases out.  The complexity to providing additional templates like DIN, JIS, etc. is the accompanying standards that go along with them. It's more than just the titleblock geometry. Other issues like dimension styles, symbols, etc. also need to be included to fully support this.  We do have support for other standards on roadmap, but in the near term we only have ASME/ISO available.
Chris
kitingmare
are there any news about supporting a DIN standart in the drawings ?
Greetings,
Marius
schneik-adsk
Please email your DIN titleblock to kevin <DOT> schneider <AT> autodesk <dot> com
Kevin Schneider
schneik-adsk
do you want the attribute prompts auf Deutsch order English?
Kevin Schneider
