Dimensions Report / Cut-list
Hi there!
I'm trying to find a 3D software that generates a list of dimensions of every part/element used on the project.
I know that Fusion has the BOM feature, but I just want a list with the lenght, width and thickness of the parts. Is this possible with Fusion?
Can someone help me?
Thank you so much!
paul.clauss
Hi @Anonymous
Thanks for posting! While Fusion 360 does not have a function to create a report of every dimension used in a component, you may be able to use  the CSV-BOM add-in to output a CSV table that includes x, y, and z bounding box dimensions. You can install the add-in using the instructions here.
I hope this helps! Please let me know if you have any questions.
Paul Clauss
Product Support Specialist
It did help! Thank you so much!
adesk.dns
Ran into this issue with only about 50 parts.  Ended up writing a small python script that
- prints out size report (dimensions sorted, longest last)
- updates component description so it will show up in part list table on drawings
import adsk.core, adsk.fusion
def run(context):
    app = adsk.core.Application.get()
    product = app.activeProduct
    design = adsk.fusion.Design.cast(product)
    # Get the root component of the active design.
    rootComp = design.rootComponent
    # Get occurences from root
    occurrences = rootComp.occurrences
    for idx in range(0, occurrences.count):
        occ = occurrences.item(idx)
        subcomp = occ.component
        for bidx in range(0, subcomp.bRepBodies.count):
            body = subcomp.bRepBodies.item(bidx)
            dimvector = body.boundingBox.minPoint.vectorTo(body.boundingBox.maxPoint).asPoint()
            dims=sorted(dimvector.asArray())
            formx = product.unitsManager.formatInternalValue(dims[0])
            formy = product.unitsManager.formatInternalValue(dims[1])
            formz = product.unitsManager.formatInternalValue(dims[2])
            print (f'{idx},{body.name}, {formx}, {formy}, {formz}\r')
            subcomp.description=f'{formx} x {formy} x {formz}'
Save to file, open Text Commands and switch to `(x) Py`
Run this command:
import neu_dev; neu_dev.run_script("/path-to-file/partsizes.py")
Prints part dimension list that looks like this:
3,Front side, 1.50 in, 3.00 in, 54.00 in
4,Inside width support, 1.50 in, 3.00 in, 33.00 in
5,Inside width support (1), 1.50 in, 3.00 in, 33.00 in
6,Body1, 1.50 in, 3.00 in, 28.50 in
rgC9VPT
Community Visitor
Community Visitor
Unfortunately the the CSV-BOM add-in doesn't appear to be available any more - does anyone have further suggestions. Thanks
i.fanariotis
hi 🙂
I am getting this message
import neu_dev; neu_dev.run_script("/Users/mustakis/Desktop/partsizes.py")
Traceback (most recent call last):
File "<string>", line 1, in <module>
NeutronPythonException.TextCmdException: File "<string>", line 1
SyntaxError: invalid syntax
