Dimensioning to tube or pipe "center line radius" (CLR)
Four year old thread here: https://forums.autodesk.com/t5/fusion-360-design-validate/how-to-dimension-to-a-radius-centreline/td...
Two year old archived community post here: https://forums.autodesk.com/t5/fusion-360-ideastation-archived/centerlines-for-curves-in-drawings/id...
I can't see this on the roadmap as per the community post.....so.....
1. Anyone know if its is happening? Or,
2. Anyone know a work around to dimension to a tube CLR? Sorta essential for tube bending as dies are all measured to the CLR.
There was one suggested workaround I've pasted below, but I can't figure how to make this work, so any suggestions would be appreciated....
"If you create the solid model using a 2D Scetch, for example lofting a tube or similar on a path, you can right click and create the sketch as normal construction, and/or when you create drawing make sure that the browser is expanded to show sketches and turn the sketch lightbulb on, you should then have a CL on the tube, rid or wire with a curve."
I haven't been able to figure this part out: "....you can right click and create the sketch as normal construction...."
TIA
