Dimensioning an angle in reference to the horizontal axis
carson9T2H5
carson9T2H5
Hello!
I'm still relatively new to making drawings using using Fusion 360. Could anyone help me figure out how to make a dimension relative to the horizontal / vertical axis of the plane of the drawing?
For reference, I'm trying to dimension the angle of the blue line in reference to the horizontal. The best I've been able to do is to make a sketch on the drawing with a line acting the horizontal axis (the red line), then dimension it in reference to sketch line. However, even then, I get a warning saying my dimension is not associated.
Any help would be much appreciated!
g-andresen
please share the file
File > Export > save as f3d on local drive > attach to post
günther
carson9T2H5
Unfortunately I can't do that, as the file contains proprietary information.
ClintBrown3D
Hey @carson9T2H5
Dimensions placed between sketches and geometry will show as disassociated.
If you placed the dimension between the angled edge and the horizontal line of the center mark, the angle would show.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
carson9T2H5
But is there anyway to make it so the angle is referenced like the one shown above? I want the angle to be referenced from the "imaginary horizontal" that is directly connected to the endpoint of the line, not the closest center mark, even if it gives the same angle.
g-andresen
Create a dummy file to illustrate the situation
günther
