Dimensional printout from model?
AnimalMother224
AnimalMother224
Is there an option in 360 to print out a cut sheat for dimensional references (blue print, schematic, etc etc) from a modeled item in 360?
Id like to draw up a concept then print it out with dimensions on it to take it to my manual machines
TrippyLighting
You can right-click on any component (not Body) and select create drawing from component.
If you did not create ant\y components in your design process but just bodies then you need to convert these bodies into components.
AnimalMother224
the Create Drawing module is spot on for what I was looking for.  Ironicly, I JUST received an instructional email that was step by step on exactly what i was looking for.
TrippyLighting
Good to hear it's working for you. Inthat case, it would be helpful if you could mark one of the of the posts in this thrad as the solution so we can move on to other threads 😉
AnimalMother224
will do.  Im just getting used to how this community is set up.  very cool you can toggle a solution to make getting help easier.
