Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Dimension line covering section view dash line in drawing
1 REPLY 1
timothy.sheaF5QWE
352 Views, 1 Reply
I have a drawing of a part that requires a section view through the centerline of a hole, I also need to locate this hole. However, the dimension line covers over the dashed line of the section plane.
I cannot figure out how to hide one side of the dimension lines nor does the dimension like being referenced to the section plane line.
I attached a picture in case my wording is not clear.
If someone could point me towards a solution that would be appreciated.
1 REPLY 1
It is not possible to prevent the overlapping of the dimension extension line and the Section line at this time in Fusion 360.  What you have is acceptable according to drafting standards so I would not worry about it.  There is an alternative, but it results in a Disassociated Dimension.  If you want to use it, dimension from the corner of the Section Line to the object edge.  The yellow triangle, denoting the Disassociated Dimension will only show up in the drawing, not in the print out or any exported drawing such as a PDF.
Drawing ViewDrawing ViewPDF ViewPDF View
John Hackney, Retired
