Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Dimension line between circles
5 REPLIES 5
alexandwirtz
830 Views, 5 Replies
Dear Support and Forum,
I'm trying to dimension between two radii, Fusion just lets me pick the standard snap points. -Please see the short screencast
Any suggestion on this? -for help I would be thankful!
Alex
5 REPLIES 5
in reply to: alexandwirtz
Dimensions will always snap to key points in your geometry. From your example it appears you are trying to select an arbitrary point along the arc which Sketchup doesn't understand.
Does snapping to the center point of the circles give you the desired result?
chrisplyler
Go back into the model workspace.
Either make a new sketch, or edit an existing sketch that is appropriate.
Put a construction line between the two radius center points.
Put points on that construction line where it intersects the two arcs.
Now, when you go back into the drawing view, you will get snap points at the right spots.
g-andresen
if you don't like an extra line just set 2 points
günther
alexandwirtz
Thanks for your help! -dimensioning the center of the arc is not an option, the opening between the arcs needs to be within a tolerance. The drawing is for an aluminium extrusion-profile.
Thanks!
