Message 1 of 9
I needed to make a change very early in the timeline, which caused some downstream failures. I was able to fix all of them except for the Axis 4 joint system.
Here is an older version that shows what it should looks like (v35):
Here is what it looks like now (latest v40):
You can see that the Axis 4 metal rod (highlighted in red) is not in the correct place. It has been moved and rotated.
Please open the older v35 file, hide the housing, then playing the Axis 4 motion study to understand what the animation should look like.
How do I fix this issue?
