Announcements
Different perspective view depending on the selected viewport
I just noticed this little glitch related to perspective viewport.
TrippyLighting
You might want to put some object into the view and see if that still happens. Chances are it does not. It works fine on my iMac.
It is also happening when there are objects in the scene.
JamieGilchrist
hi ivanjovanovic19,
is it the camera "jittering" as you toggle back and forth between an ortho window and your iso/perspective window?  just looking for a little more clarification.
thanks in advance for your response.
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
JamieGilchrist
hi ivanjovanovic19,
thanks for finding this, I've logged a bug so it can get into our backlog for prioritizing and fixing.
In the mean, time try changing your Grid Settings to Fixed, this should take care of the undesirable behaviour.
what I think is happening is the adaptive grid, which is supposed to adjust spacing and subdivisions based on zoom level, is shifting based on the zoom differences between your ortho and perspctive windows and applying the grid spacing based on the active window to all the windows instead of maintaining each windows zoom level and corresponding grid adaptation.
 hope this helps.
hope this helps,
Jamie Gilchrist
Thank you.
It was annoying. God only knows when did I change this setting.
Thanks again 🙂
I.
