Diagonal Pattern Idea
rassadinyar
rassadinyar
Hello.
Clip_5.jpgI think it would be a good idea to introduce an algorithm for the diagonal pattern. So it turns out that sometimes we need to make a grid more complicated than rectangular. We have to make a complicated first sketch to get exactly into the grid. It would be cool to have a pattern that comes from the center in different directions. It would be possible to create more complex patterns in a simpler way.
alexwbakker
For so many reasons, I agree. This is annoying to do, especially if you don’t want to pre-calculate the spacing, or want to have a center point. For so many decorative and functional use cases, having a brickwork pattern like in illustrator would be great
etfrench
You can create rectangular patterns at any angle you choose.
ETFrench
TrippyLighting
Good idea. I think that the examples in your post still cannot be achieved with a diagonal or staggered pattern.
Those examples are possibly from Rhino/Grasshopper and were created using procedural modeling techniques.
As it pertains to Fusion, that train has completely left  the station.
TrippyLighting
That isn't really the problem. A staggered "brick"  pattern can indeed be achieved with some sketching and math, but there are some drawbacks to those methods.
There are a number of other pattern tools found in a number of other CAD software that would be really nice to have in Fusion.
alexwbakker
The diagonal sketch definitely doesn't work for my most common use case - a single instance of a patterned object that needs to fill a rectangular panel , but starting from a corner. the rectangular pattern cannot "alternate" the rows, it just keeps offsetting in the same direction. A brickwork pattern would be very handy for parametric things, too, since having to have the sketches, offsets, and having to have variables compute the spacing now is all quite error prone.
etfrench
If one doesn't work, use two:
ETFrench
