designing a component that fits a fluid shape
CuttingEdgeManufacturing
Message 1 of 10
I am working on a project that i cannot share photos of, as i signed a NDA. but i am having issues with a portion of the design. basically, i have an opening of a fluid shape. i need to make a cover that would fit snugly over this opening. i am having a hard time figuring out how to design this portion.
below is a picture of some car on grabcad. in a nutshell i need to make something similar to the windshield, where as i need to fill a 3 dimensional hole in a model with a seperate shape.
the only difference is instead of actually filling the void i need it to sit overtop the frame. so basically extend and sit on top of the supports.
i hope i explained this good enough
any help would be appreciated.
Replies (9)
Message 2 of 10
TheCADWhisperer
No picture?
Can you create a dummy mock-up file to demonstrate the same behavior/Design Intent, without violating NDA?
I am thinking Patch and Thicken.
Message 3 of 10
yikes i stopped the browser after i clicked post but it must of been too late. i reposted it already here is link
https://forums.autodesk.com/t5/fusion-360-design-validate/help-with-modeling/td-p/9612366
Message 4 of 10
im not sure patch would work as that fills the void not sits on top and extends over the frame. ill give it a go though.
Message 5 of 10
jeff_strater
I think this is a duplicate post with this one:  help-with-modeling
Jeff Strater
Engineering Director
Message 6 of 10
yes it is. i linked it to the other post myself in my first reply!
Message 7 of 10
TheCADWhisperer
Surface Patch
Offset
Thicken
Message 8 of 10
basically i need it to protrude outward, almost like dome out for clearance. can that be done with the work flow you mentioned?
currently i am projecting all the surfaces, and extruding. and doing this in 3 different axis, gets me a rough shape.
Message 9 of 10
TheCADWhisperer
Message 10 of 10
works perfectly. thank you! i rarely have used the patch workspace!
im used to more dimensional designs. and primarily programming so this was a task!
