Design template
Design template
erik
Design template
erik
I was wondering whether or not the Fusion Team are considering implementing Design Templates, where the user is able to set the preferences to either open an empty .f3d file when starting a new design or an .f3d file from a specific location on the cloud or the computer?
I found a post on the forum which shows that storing a .f3d on the computer and starting a new design from file would serve as a workaround. But the post is from a year ago and therefore I was wondering if it is being considered.
- Erik
lucasproko
Hey @erik,
If you wanted to use a certain design as a template for further files, you have three options I can think of:
  1. You export the initial design and then do "New Design From File" as you mentioned
  2. You can copy the current design using a Save As, or a Copy command to have a duplicate of the design
  3. You can insert the "template" design into a new design and then either maintain the link, or break the link and the references will now be in your file.
Do these options allow you to perform your desired workflows, or is there something missing? Could you describe in a bit more detail exactly what you would be using these design templates for and what your desired workflow would be?
Thanks!
Lucas Prokopiak
Fusion 360 Product Manager (Sketch/Model)
erik
Well, the workflows you describe does the job, but I would like to have a setting like in a browser where the user can choose the behaviour for opening a new tab and the program. This could be set in the preferences along with the other user specific settings.
With this setting the workflow would be something like this: I will start Fusion (it will automatically open a copy of a template file with the link broken to it) and instantly jump into the task and begin working on the design because all my components and sketches are already setup. At some point when working on the design I will save the file and name it, because it is unnamed per default. When I finish the task I press 'new file from template' (new button located between 'New Design' and 'New Design From File') or the plus symbol next to the tabs representing open documents. Fusion then opens a copy of the same template file with the link broken and I am ready once again to work.
Whether the template file has to be in the cloud as the Drawing template tiles have to does not play a role.
Also, it would be great if one is able to set behavior for both starting Fusion, pressing the plus symbol and closing the last file, where Fusion just open a new empty file.
I hope this makes sense 🙂
- Erik
