Design Table
Design Table
Design Table
I gave this a search and couldn't find much on the topic, but by chance does Fusion 360 have design table capabilities similar to those found in Solidworks?
If not, are there plans to add this in the future (if so, ETA?)? Thank you in advance!
Daniel_Graham
Hello, thanks for reaching out.  We do not currently offer the same functionality as Design Tables in SW.
When you ask about Design Table functionality what are the main things that you would like to use it for?
  • Part configuration or Assembly configuration?
  • Vary the values of dimensions to make geometric variations of a design?
  • Control the suppression state of features?
  • Vary the material?
  • Vary properties / metadata?
  • Other?
Thanks for further information,
Daniel
Hi Daniel!
I'd love to be able to quickly and effectively change my models based on varying part requirements. For example, I currently have a modeled fixture that I can use for various tasks. However the basic dimensions will vary slightly depending on the required task. Being able to quickly change model properties and building formulas into the design table to appropriately accommodate these design changes would be very advantageous to me and my work
You can use the Modify Parameters feature to build in variables and formulas into your design dimensions.
Here's a video on how to use them:
That was very helpful dzehner2, thank you!
Glad I could help!
