Design - Show expression not result on dimension marks
fcad6SRUG
fcad6SRUG
While in most cases it is better to show the result, is it possible to change the view so dimension marks show the expression behind them instead of the resulting numeric value?
E.g. instead of "2mm" show "Width - Relief" based on some view option?
Yes, I know I can click on it to see them individually (well, sort of -- if they fit well in the box).  But to understand a sketch better it would be nice to be able to view overall.
TrippyLighting
That is a very good suggestion!
christian_smith
Hi @fcad6SRUG, thank you for the suggestion. I will ensure to pass this along to the team.
If you are not already part of or Fusion Insiders program, I would encourage you to sign up. In there you can post your idea, and future ideas, directly to our product teams. https://feedback.autodesk.com/key/fusion360insider
Christian Smith
