design sequence of segments
Message 1 of 24
I have difficulties in creating a sequence of segments.
In Sketch, I draw the first segment, then, before drawing the following segment, I try to assign length and angle; when I do that, most of the times, the first segment turns from black to cyan and  the following segment looks to be an arc, not a segment, also cyan.
I feel I am doing something wrong with the mouse: which is the correct way to do that ? Where can I find information with the correct use of mouse ?
Thank you.
Mauro Caroti
Replies (23)
Message 21 of 24
TheCADWhisperer
So far it looks good.
Can you finish it now?
Message 22 of 24
Jeff,
I understand that is very difficult to make a perfect diagnosis of the problem without almost any documentation.
The paper clip that I just sent looks OK to me: I draw the clip for the geometry, and afterwards I quoted all the segments.
I think that you are right, the problem resides on how I use the mouse: I feel that I should practice a bit until I find out the best way not to have problems any more.
Thank you.
Mauro
Message 23 of 24
I will do it tomorrow, as it is somehow late here in Italy.
Thanks to you for the support.
Mauro
Message 24 of 24
TheCADWhisperer
Here is an alternative technique...
https://autode.sk/37xrRBn
