Design parameter using driven dimension does not update when used in other sketch
deutirium
deutirium
I have a design where I need to use the driven dimension for the length of a line to create a rectangle in another dimension. I created a new parameter using the driven dimension as its expression, and then used that parameter to create the rectangle. Now that I've editted my original sketch, which changes the length of the line and thus the value of the driven dimension, this update is not reflected on my rectangle. Even clicking compute sketch does not update the value. I have to open the dialogue box for the dimension in the box change, CHANGE NOTHING, and press enter and now it figures out that the value has changes. How can I catch this when it happens? How can I avoid it happening entirely? I think the following screenshots explain it well enough.
Both numbers should be identical
Proof that the dimension is being referenced
clicking the fx button shows the new updated value.
pressing enter updates to the correct, new, dimension.
I've attatched an editted version of the file. The driven dimension being referenced is in the first sketch, and the wrong dimension is in the final sketch. Apologies for not cleaning the file further as I would be afraid it would affect the behaviour. Anything between those two sketches is unnecessary.
TrippyLighting
Have you run a "Modify->Compute All" ?
deutirium
Thank you, that fixed it indeed. I still don't know WHY it's happening (and it shouldn't be), but at least now I know to do this manually whenever I feel I've made a modification which will impact other parts of my design.
