Derived Dimensions - is it possible to see any constraints that are forcing a derived dimension?
mrector333
Message 1 of 1
mrector333
when using a complex sketch, sometimes, it's hard to find what is stopping you from specifying a dimension. It may be measurements from origin, or from other points or lines, or it may be parallel or perpendicular or angular constraints.  Is there a way to see what is causing the issue?  It would be need if there were a button on the pop-up derived dimension notification "Show constraints" and it would highlight them in red on the sketch (or something like this).
Replies (0)
