Deleting Fusion 360 Files
Message 1 of 8
Why is it not sometimes not possible to delete files, even if those files are not used in another design.
Replies (7)
Message 2 of 8
Phil.E
Were these files ever inserted into another design, or was a drawing made from them?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 8
that got me thinking and I found the (i) Infobutton and the parent drawing.
There is one file (one of my first designs) however that keep crashing Fusion while opening and I can't delete it.
It would be cool, if it were possible to force an delete.
Tobias
Message 4 of 8
Phil.E
I would very much like to help here. There are a couple things going on.
First: any repeatable crash can be fixed. So I would like to get access to the model.
Second: I can help you figure out where the file is referenced and try to get it deleted.
Third: I don't see any recent CER reports from you related to this. Are you getting the usual CER form to fill out when you crash?
In order to investigate further, I need access to your data.
Can you invite me to the project?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 8
I just send a report
CER_119185175
Where can I find your e-mail-adress or is there another way to add you too the project?
Tobias
Message 6 of 8
daniel_lyall
a work around is to delete everything in the drawing file save it then you can get ride of it
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 8 of 8
I wonder why its not possible to delete old versions of a design ?
If that was possible, one self could just remove previous versions of assemblies, and thus remove such old references.
....problem solved.
