Delete individual constraints of a sketch point stack (or loosen from origin)
samuel.beer
samuel.beer
This is a problem I come across often and I thought I'd eventually get behind it, but after about 1 year total of using fusion360 I still can't seem to do this: I want to delete the concident constraint on a circle center which binds it to the component origin. Now when I draw multiple circles it seems that fusion360 will create a sketch point for each circle (at least that is what I get from leftmouse & holding -> contextmenu). But whichever point I select, the concident constraint is just not there and I can't delete it.
Same happens for points that lie on projected points. It's always a game of chance if I find the projection constraint or not. What also bugs me is that after fusion360 logic, a point stack is indicated with black circles. However this is a white circle? And it's clearly more than 1 point as seen from the contextmenu...
Please help me grasp this properly. I fear I'm missunderstanding something.
mango.freund
hello, you have to click on the line very close to the connection point. then the constraints become visible. maybe repeat several times.
g-andresen
I agree, it's a bit tricky, especially with projections.
In the meantime, this is how I do it.
günther
