delete in browser does not delete
I have come across a problem with deleting objects in the browser. There are times when this does not work. I am working with timeline disabled.
See example here: http://autode.sk/1TAydPA
after restarting Fusion 360 I was able to delete:
I also had problems deleting selection sets in the browser. Mentioned in an other toppic:
Link to toppic
I think this must be a bug.
TrippyLighting
The problem is likely that the items you are trying to delete are "linked" to another object in the browswer.For example tt may be that one component references a sketch in amother component.
Unless you delet that connection you cannot delet the referecing object.
Thanks for looking at this.
It is a very good suggestion that a reference leads to not being able to delete an object. I will observe that. However in this particular case I remember that a Fusion 360 restart was all it took to be able to delete the object. I will doublecheck next time.
